  #1
Old April 4th, 2005, 04:13 PM
blacktip18 blacktip18 is offline
Default Aluminum fuel tank repair?
I have some small pin holes around one of the fittings on the top of my 30gal aluminum belly tank. Is there a way to fix this. Like a liquid metal or some sort of sealent. Or is my only option to open the floor and replace the tank. $$$It's a 18ft center console with 88hp Evinrude outboard
  #2
Old April 4th, 2005, 11:44 PM
Winger Ed. Winger Ed. is offline
Default Re: Aluminum fuel tank repair?
"JB Weld" will work. Just clean it real well and scuff sand the area for it to hold better.I'd sure check it over very carefully. Those holes may be indicitave of its overall condition. If there is much more than just them, I'd be thinking about replacing it.
  #3
Old April 5th, 2005, 10:51 AM
Boomyal's Avatar
Boomyal Boomyal is offline
Word has it that MarineTex would be a better epoxy to repair gas tanks. Are the holes all the way thru?
  #4
Old April 6th, 2005, 01:55 PM
Chris1956 Chris1956 is offline
Blacktip, I use Marine-Tex and cloth on gas tank repairs. Clean the area by sanding and wiping with acetone. Cut the cloth to size and then try to work the Marine-tex into the cloth fibers, place the cloth over the area under repair, and use a putty knife to make it smooth. It works very well.
  #5
Old April 7th, 2005, 05:59 AM
martinmanfan martinmanfan is offline
I don't know the economics in your neck of the woods, but wouldn't replacing the tank make sense since galvanic corrosion is present? I just fabricated a 25 gal. belly tank at our shop and the guy was charged $85 which included fittings....I feel this is too good of a price, but I didn't write the work order...As for patching, I would think you will be getting more pin holes in the near future due to the corrosion getting a firmer grip on the material...
  #6
Old April 7th, 2005, 06:37 AM
Scali Scali is offline
Marine tex, once used it to repair a cracked oil pan on a 72 Bronco I used to thrash..repair lasted till I sold it @v least 3 years.My vote is for Marine Tex.
  #7
Old April 8th, 2005, 07:59 AM
swimmin' for shore swimmin' for shore is offline
I have to go with the new tank. It just isn't worth finding out too late that you had more leaks, just beneath the surface. Martinmanfan, 85 dollars??? I thought about going with a couple of tanks in the floor of one of my boats, and they were basically just obsolete triangles. The price quote, per tank, was 1100 dollars with it's fittings. Send me your shop's phone number before they go out of business.
  #8
Old April 11th, 2005, 07:21 AM
Yeah, that was last year....($85)...That tank should have cost that guy $250, but that's what the work order read...Maybe he was a buddy or something...That was here in Yakima...ASAP can be reached at 509-453-9143...
  #9
Old April 11th, 2005, 11:18 PM
cc lancer cc lancer is offline
If these pin holes are from corrosion, it a good bet you also have corrosion on the bottom.
  #10
Old August 14th, 2007, 09:25 PM
fishtale1212 fishtale1212 is offline
Quote:
If the tank is 12 yrs. or older I think you are bettert off to replace it instead of worring about leakes in the future
  #11
Old August 14th, 2007, 11:24 PM
dingbat's Avatar
dingbat dingbat is offline
If it has holes in the top it certainly isn’t far from having holes in the bottom as well.
Tearing up the floor to replace the tank now is a lot less of a headache than trying to figure out how to get 30 gallons of fuel out of the bilge when the old tank lets loose.
  #12
Old August 14th, 2007, 11:46 PM
redfury's Avatar
redfury redfury is offline
And when you do, you can replace it with a plastic tank that can't corrode....
  #13
Old August 15th, 2007, 12:21 AM
Big Keepers's Avatar
Big Keepers Big Keepers is offline
Send a message via AIM to Big Keepers
Quote:
Exactly what I was going to say. The new polyethylene tanks won't suffer the problems aluminum tanks do after time. Plus ethanol doesn't give a hoot about plastic tanks. Cars have been using them for a long time. I'm restoring my MFG and I am lucky that I can unscrew a hatch and remove the tank in about fifteen minutes. Your situation is different if the decking needs to be pulled or possibly cut. Its understandable. However here are the hard facts.
You have got pin holes in your tank. I don't care how big or small they are, they are holes. Even if you patch it, I wouldn't feel safe if the tank wasn't pressure tested afterwards. Save some money and when you have enough replace the tank. For a bit of reference, I got a price quote for a new 45 gallon aluminum tank from a local here on Long Island. He said it would be about $315 for the new tank. How much is your peace of mind worth? A leaking gas tank brings about a slew of horrible possibilites, least of which is gas in your bilge. Perhaps you can temporarily use a 12 gallon above deck tank from Tempo?
Gas vapor + any small spark or electrical surge = Bye Bye Blacktip
__________________
  #14
Old August 15th, 2007, 12:23 AM
rdmmdr rdmmdr is offline
had to replace the tank in a twin console wahoo/ whaler, tank in the glassed in seat hump.. i was about ready to kill my self, cut the hump out, fix the tank ,reinstall, feather edge the glass,epoxy back in, and regelcoat the entire interior to match. for five hundred bucks had a stainless trim cover made to match the hump with backing plates. that wahoo now has a removable tank and got it done over the weekend. no glass work. just alot of 5200. if you have to go to this much hassle to fix the tank replace it.
rick
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
removing Aluminum Fuel tank doctorrazz Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 March 22nd, 2006 05:56 PM
installing above deck aluminum fuel tank 93bronco Boat Topics and Questions (not engine topics) 2 August 28th, 2003 04:21 PM
built-in aluminum fuel tank or portable tanks? beachd Boat Topics and Questions (not engine topics) 2 April 9th, 2003 11:35 AM
aluminum fuel tank 12 years old bonitoman Boat Topics and Questions (not engine topics) 3 March 3rd, 2003 05:09 AM
aluminum or plastic fuel tank? kjpfish Non-Repair Outboard Discussions 20 December 30th, 2001 07:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
