Re: 87 Force 85 dry Plugs wont start
Once in a while my port motor won't start.
I found this the hard way.
I was frustraded and PO'd
I turned the key while the motor was in the tilted up position.
It fired and started.Turned it off and lowered it and it started right up/
You have no electronic primer but a electric choke.
Push in as you turn the choke.
The fast idle: pull the handle out or maybe a button on the control box.
Pull ing handle disengages the shift linkage and allows the motor to be reved up in neutral.
What are the actual compression#s ?
They should be within 5# of each other. Say 120 on all.
But if the top is 125 and the bottom is 110 that would be enough to make it hard to start.
Too bad you ordered reeds.I'd would have sent you some I have setting here
