Re: On board charger putting out 10 volts DC
When measuring the voltage of a 12-Volt battery, you need to measure the voltage to at least 0.1-Volt resolution in order to provide useful information, that is, information that has diagnostic value. The Voltmeter should have an accuracy of at least 0.5-percent. At 12-Volts, 0.5-percent is a variation of [0.06-Volts].
A "12-Volt" battery that is completely discharged will have a terminal voltage of 10.5-Volts. All voltages related to state of charge are subject to some variation for temperature. The voltages I mention are for nominal temperature, say 70-degree-F.
To charge a 12-Volt lead-acid battery you must connect a source of current to its terminals with a source voltage that is greater than the terminal voltage of the battery. When you do this, current flows from the charger into the battery, where it can be stored.
To fully charge a 12-Volt battery you must raise the terminal voltage above 12.9-Volts. A typical 12-Volt battery charger will raise the terminal voltage of a 12-Volt battery at full-charge to around 14.4-Volts. After the charger is disconnected, the battery terminal voltage will drop, and the charge will dissipate until the resting voltage of a fully-charged battery is around 12.9-Volts.
A charger that has only limited current available that is connected to deeply discharged battery whose terminal voltage is 10.5-Volts may not have enough capacity to pull the terminal voltage up very much. It may only pull up the terminal voltage slightly. However, if you leave the charger connected and let it build charge in the battery over many hours, the terminal voltage will slowly rise, reaching 12.9-Volts or more. It is probably prudent to slowly charge a battery that is completely discharged than to try to push 100-Amperes into the battery in a few minutes.
Having worked with battery powered equipment all my life and been responsible for the repair and maintenance of battery-powered equipment, I have developed a simple rule to use when diagnosing problems in the operation of battery-operated equipment:
If a battery-operated device appears to malfunction, the first component to test is the battery.
Lead-acid storage batteries that are allowed to sit for long periods at deep discharge states are often damaged beyond recovery. The storage of electricity in the battery is a chemical reaction that is reversible. However, if allowed to sit in a dormant state with a deep discharge, the chemistry can often not be restored, and the battery becomes permanently damaged.
If you need a battery to start your boat's engine, it is reckless to not have a reliable battery. Most boaters whose boat engine cannot be started without a battery usually carry two batteries on board to ensure good engine starting.
