Hi guys I'm new to the forum, but have been reading lots of post on here and am glad there is such a site with so many helpful people. I bought a 19' sea ray seville really cheap and I knew it had rotten stringers before hand. My plan is to replace the stringers, floor/deck, build new jumper seats, have 2 captains/helm seats and then bench seats behind them in place of the sleeper seats. I will also be redoing the side panels, along with the rest of the upholstry, as well a new paint job.
A few question i have are,
1) why laminate 2 pieces of 3/4' plywood for the stringers, wouldnt it be easier going with a full length 2 by 6 or 8?
2) is it wise to go 3/4' for the floor, it was only 1/2' to begin with
3) can i use 1.5 csm all around, or do i need to use biaxial after a layer of csm?
4) there is a section in the hull directly under the ski locker area where the hull seems to be patched, i want to strengthen it up from the inside, what should i use? and then do i grind and gel coat the exterior??
5) can i paint over the gel coat?? i want to completely change the color
Ive attached some pics of the boat, the first 2 are of the area in question 4
