Re: 1971 Evinrude 60 HP Motor Knock
The noise could be a bad wrist pin in a piston. The bad wrist pin would probably allow the piston enough slack to wallow out the hole and show bad compression. I'm no expert on this. I've had seen a bad wrist pin on a couple of outboards and they both showed bad compression. I've had a crankshaft main bearing cage come apart and it also resulted in very low compression on the cylinder that got cage pieces between the cylinder and the piston. A slight tick of a loose wrist pin probably wouldn't cause bad compression, but if you're hearing the knock on idle and it's from a bad wrist pin you'd almost positively have bad compression.
You could take a wrench and turn each piston until right before top dead center and stick a clean screwdriver in the spark plug hole and push down. Then go barely past top dead center and push again. If you feel significant slack when you push down on the piston compared to the other cylinders, it's probably a bad wrist pin.
This would be one of the worst case scenarios, so don't get all worried just because you hear a noise.
How does the engine run? Smooth at all speeds? If so, it's likely not a big deal.
JBJ
