Hey guys I have a 1978 mercury 800 SN:4836723 that i believe has a fuel issue. When I start it up on muffs at home there is not a single problem with the engine. It starts right up and keeps on trucking no problem. When I'm on the water however I have some issues. When I put the engine into gear it almost always dies. Its quite a routine to get the warm up throttle down and put it into gear with enough gas to get it moving before it dies. Also at WOT every once in a while it will start bogging down and die. Then its about 20mins of me cranking on it to get it restarted again.
I was going to start by rebuilding the carburetors and possible putting on a canister fuel filter. I have been looking all morning for the carburetor rebuild kits and so far i think I need this one 812953. So, is this the correct rebuild kit? Do I need to buy a float separate from it? I ask about the float because I have been looking at this kit on a bunch of sites and some of the pictures have the float, and some of them don't.
Also, what do you think about a separate fuel filter? I have read in some posts that they are wonderful and in others that they suck and you will have problems with them.
