I?m replacing my 1977 model Evinrude Cross-Flow 140 HP V-4 with a Johnson 1995 model 150 HP Loop Charged motor and have a few questions.
The wiring harness connector plug inside each motor looks identical to each other including the location of every connector pin. Are these plugs compatible with each pin providing the same function? The control box that?s on my pontoon boat has the wiring harness going into it including the ignition switch and I was planning on using it if possible. The wiring harness that?s on the boat where the newer Johnson 150 came from is built into the boat and I can?t see removing it along with the throttle box and control cables (which are too short) if I don?t have to. Could it be as easy as just plugging in the main wiring harness connector and using my existing throttle and shift cables? The cables look the same but I don?t have them disconnected yet for a complete view.
I know I?ll have to do some work on the power trim wiring but I don?t think that will be too big of a deal but any input on that would be appreciated also.
The Johnson 150 HP is a new motor to me and I tested the compression (with all plugs out) and all cylinders showed about 95 PSI across the board. All of the spark plugs looked the same with very little discoloration. Does this look like good compression? The motor has not been run in a year or so.
Thanks for any help in this conversion
