fisherman67
- Jan 27, 2011
- 11
Why do the johnson 2 cylinder outboards have a tendacy to runaway to high rpm's when you have them hooked to a flushing device? It has happened to me twice while I was flushing the motor, turned off the key, the fuel line was already unhooked and I even pulled the spark plug wires off and it still would not shut down, only after about a minute of running away at very high rpm's did it finally shut down. This is a 48hp 1986 johnson. It also happened to my brother's 55hp when he was flushing it out. Happened from an idle without throttling it up. Help, why does it do this?
