Re: 1989 johnson 110hp vro
welcome
normally we start with a health check then basic service and that fixes most problems.
Health check : compression test (borrow one from autoparts store and have them load test the battery for free while you are there). buy a spark tester as its a tool thats worth having. once you know the compression is good and you have a good spark on all cylinders then servicing the carbs, water pump and replacing spark plugs (all easy jobs). There are videos on you-tube that show a outboard carb rebuild so you can see whats involved.
1989 Johnson Evinrude 110 hp Outboard Parts by Model Number this will give you a idea on costs for the carb kits a impellor and plugs but its always compression test first
generally most problems are detected and fixed by the time you have done the above and we can help you with anything thats either a problem or is diffrent from most
