mguidry629
- Sep 19, 2011
- 53
1) Performance issue you are trying to correct.
- Not sure yet. I'd like some opinions whether the boat is capable of higher cruising speeds / top end and MPG
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
- Boat currently has SS Merc 3 blade 13 3/4" x 21P (48-73982-A4) on the drive
- Included with the boat was (1) Alum Merc 14 x 19P prop and (1) Michigan 14 x 19 SS prop
- All 3 props are in good shape, but I've only tested the 21P prop that's on the drive
3) Current prop diameter and pitch (required).
- 13 3/4 x 21P
4) Wide open throttle RPM and speed with an average load (very helpful)
-4200 @ 45 mph
5) Engine/drive make, model, year, and HP
-Mercruiser 5.7 260HP / Alpha One, 1987, 260HP (not original motor, but OEM replacement)
6) Boat make model, year, length and weight
-1987 Chris Craft 230 Limited / 22' length / 2800 dry (3800 with gas and family aboard?)
I purchased this boat from my wife's grandfather last year. I had transom redone, etc, etc....lots of work (still in progress but mechanically good to go, just touching up on some cosmetic issues now)
My wife's uncle that helped maintain the boat said they tried several different props on this boat and 45mph is top speed at 4200rpms. Cruising speeds around 3400-3600rpms in the 35-38mph range. I know they tried the 19p Michigan prop but obviously had better results with the 21p, since that's the prop that was on the drive when I bought it.
Merc prop selector suggests 16 or 17 pitch or Rev 4 15 pitch. This is main reason I'm posting this thread for advice since they are suggesting a much lower pitch. I'd like to add that they only have the 1.47 Gear Ratio option, not 1.5 which is what I have. Also would like to know what the max RPM should be for this motor?
- 13 3/4 x 21P
-4200 @ 45 mph
