  #1
Old March 27th, 2005, 10:47 AM
beertech44 beertech44 is offline
Default replacing floor aluminum rivets
I have a 1979 sea nymph with a rotton floor. Problem is to replace the floor all the inside stuff has to come out and is riveted to the sides of the boat. Stuff like the side console steering and seat bases. Question is how hard are Rivets to install back when the floor is done. I haven't even found a place to buy them yet but they look like solid rivets with the inside squished. Am I going to have a problem getting them tight. Even though they are above the waterline I want stuff tight.
  #2
Old March 27th, 2005, 01:49 PM
BoatBuoy BoatBuoy is offline
Default Re: replacing floor aluminum rivets
Web search for aluminum rivets will keep you busy all night.
__________________
"Technology is dominated by two types of people: those who understand what they do not manage, and those who manage what they do not understand." -
-- Putts law
  #3
Old March 27th, 2005, 01:55 PM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
I redid My 74 Starcraft back in 99/00.......I put it back together with 3/16ths" Pop-Rivits............Almost 700hrs,+ Not a Problem At All...........
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #4
Old March 27th, 2005, 02:17 PM
Wont pop rivots leak if water splashes up the side
  #5
Old March 27th, 2005, 05:11 PM
Bond-o's Avatar
Master Shipwright
The Wood in My boat is rivited to Stringers, Bulkheads,+ Ribs............BTW,.. I Also use a Closed-end Pop-Rivit Under the waterline to replace Damaged rivits.....
__________________
  #6
Old March 27th, 2005, 05:29 PM
ok I see. I have some in the side that need a sealed rivot. What is a closed end pop rivot
  #7
Old March 28th, 2005, 04:00 AM
Laddies Laddies is offline
Beertech we have replace some floors by cutting them down the middle to remove them and adding a center seam to reinstall them with good result
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #8
Old March 28th, 2005, 06:37 AM
gewf631's Avatar
gewf631 gewf631 is offline
Are you certain that the parts are riveted all the way through? Nothing inside my mid-70's Starcraft, was riveted through the hull. Most of the stuff was riveted to the ribs, or to a flange of some sort that itself was riveted to the hull.I replaced the entire floor by just drilling out all those rivets (they were all pop-rivets). When it came time to put it all back, I used stainless steel screws.
  #9
Old March 28th, 2005, 09:26 AM
ufm82 ufm82 is offline
Beertech, Welcome to the club. My first "real" boat was a 1978 Sea Nymph FM161. Same boat as yours I believe. I bought the thing and the floor was completely rotten. The transom was pretty sad as well. I strip the hull to the skin- completely gutted it and rebuilt it. I expanded the front deck, added some hatches and liners and changed the rod locker dimensions. The issue I ran into is the same thing you are seeing- the console and some of the brackets are under the waterline. My solution was to go to an industrial supply house and find a good quality closed-end rivet. I settled on a 3/16" Closed End aluminum rivet with a Stainless Steel mandrel with a 1/4" Grip Length. I also purchased a #11 drill bit- this gave me a press fit. (You have to tap the rivet in lightly with a hammer) The #11 would drill out the old rivet and create a perfectly round hole for the new rivet. Then, I used a Marson HD setter to pop them in. It would hurt your wrist to pop these rivets but they drew down very tight and left a nice smooth head when they popped. The inside end mushroomed very nicely and actually looked good. I used over 100 of these rivets during my rebuild and ran that boat for 3 years after the job and it never leaked. ( Not bad for a 20 year old boat.) I paid about $18 for 50 of those rivets. You won't find them at Home Depot or Lowe's or any place like that. Find an industrial fastener supply and they can get them for you if they don't stock them. The gun to set them should run you about $45. That will be strong enough to set the rivets. UFM82
  #10
Old March 28th, 2005, 06:50 PM
Bond-o's Avatar
Master Shipwright
These People right Here,...... Can get them,... I buy them from the Watertown store.....Unfortunately,... They Don't list the in the online catalog............UFM82,......I could have written that myself,.... Even the Marson....
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum Rivets rterrian Boat Topics and Questions (not engine topics) 7 April 24th, 2009 11:09 AM
Replacing Broken Rivets cknadroj Boat Restoration and Building 3 September 20th, 2006 06:56 PM
Replacing Rivets marcengillb Boat Topics and Questions (not engine topics) 8 January 15th, 2006 10:33 AM
Aluminum boat rivets 87Aggie Boat Topics and Questions (not engine topics) 4 March 25th, 2005 07:45 AM
tightening rivets and replacing carpet? tasbrus Boat Topics and Questions (not engine topics) 0 April 29th, 2002 08:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
