Moody Blue
- May 24, 2004
- 3,136
In the process of rebuilding this motor (thread here http://forums.iboats.com/mercury-mariner-outboards/1971-merc-800-rebuild-refurbish-589826.html) and have acquired a couple replacement reed blocks (thanks to the kindness of a fellow iboater) but they are slightly different than the originals. Want to be sure they are compatible.
On the mating surface of the "new" reed block halves there is a small machined groove leading from the labrynth seal to the outer diameter of the reed block. The original reed blocks did not have this groove. OK to use in place of the originals?
