I need some help with trolling motor installation. I will be as specific as I can so you can understand what I need to do.
I just bought an old bass boat, no trolling motor on it, but there was one at some point. On the bow panel there is a three prong plug. Next to that, there is a 12V Charge/12V Run 24V switch. There are two wires that come from the back 6 gauge wire which are the positive and negative that ran to the battery that are then spliced into some other wires that lead to panel. There are 4 more wires, lesser gauge wire, that go from the back to the front, two positive and two negative, that were connected to the switch which I?ve determined were for the 12V Charge portion of the switch. There is a jumper wire from the switch to the plug. On the back of the switch, there are 4 posts and a bar.
I have a Motorguide Tracker 60 motor that I want to put on the boat. This has a switch on the pedal that is for 12V or 24V operation. I have a two bank onboard charger that I am using to charge the two trolling motor batteries that I installed.
Here are my questions:
1) Is the switch in the pedal of the motor a conversion switch? If so, this would allow me to leave the batteries connected parallel, correct?
2) If the pedal switch is the conversion, this would allow me to disregard connecting anything to the 12V Charge/12V Run 24V switch, correct? I?m not going to use the plug to charge my batteries anyway.
3) In detail, what is the best way to create this wiring setup? From battery setup, wire gauge, circuit breaker, type of wiring connectors (e.g. getting 6 gauge wire to connect with the lesser gauge wire going into the plug). Like I?m a two year old, could someone explain this to me, I?m confused. Appreciate the help in advance.
