I am looking at picking up a trolling motor for my 17' trihull. In the past I have had bow mount foot control MK's. Since I have a very limited budget (baby on the way) I am considering a transom mount because they are pretty cheap compared to a bow mount. Is it possible to spin the control around so that it faces backwards over the propeller instead of like a tiller? I do have a kicker motor bracket on my transom, but would rather mount the motor on the bow because I am an avid bass fisherman and trying to get the wife to control the boat from the back would probably not go over too well.
What size wires would you run up to the bow for power? For a 12v motor I figured that a 80a breaker should be sufficient between the battery and the TM. Should I go larger or can I get by on a smaller one?
I have done installs on bow mounts before but I already had the boat prewired and setup with the appropriate breakers as I had just done a swap instead of a completely new setup.
Any tips, hints, tricks and other information is greatly appreciated. Also wouldn't hurt if anyone knew of a good used TM that is for sale.
