Re: New prop question
Your prop numbers should be under the prop nut.If the motor did well for you the same size prop should work.
New diameter may be slightly different but pitch is the key number.
If you read the stickys at the top of the prop forum and the helps at the prop store here it may help you understand props
better.Feel free to ask any questions.
