Been reading and studying hard for this info and can't seem to find a solution anywhere on the interwebs.
Engine runs really good especially above idle.
The (new analog) tachometer doesn't register at idle. Teleflex set to 6P. If throttle is slightly engaged it will start to read at a minimum of 700-800 rpm (correct idle?) and the engine sounds better at this point. All connections have been checked and double checked and I feel extremely confident all is well there.
Engine has been known to stall when putting into gear, but as of this afternoon it has also began to almost stall when coming from higher RPM into neutral. I feel this is directly related to the fact I cleaned the Idle Control Valve(wasn't very dirty).
So my questions are:
What are the correct voltages on the green sending wire for the Tach coming from the ignition and ECM.
How does the ECM determine the RPM of the engine? Crankshaft position sensor? Coils?
Can the idle speed be adjusted without having to adjust the TPS?
Sorry for the novel but I am at wits end and have trust issues when it comes to letting others "work" on my any things.
