My battery is 7 years old but never been used, I bought it as a spare. I charged her up and this is what I am getting.
My battery reads 12.4 Volts
When I crank the engine and keep meter on battery terminals it drops to 11 volts
When I crank the engine and keep meter on solenoid it drops to 8.1 volts
When I run jumper cables from the battery to the solenoid it reads 8.1 Volts at the solenoid
So far I have replaced the battery cables from the battery switch to the engine as they showed signs of corrosion. I have checked and I cleaned all the connections between the battery and the engine.
The logical next step is to get the battery tested while under load at the shop but figured I would throw this on the forum to see if anyone had any further insight
