Re: 75hp evinrude putting out 16 volts
I don't know about your model, but I had a 1976 70 HP that was unregulated. Voltage could get upwards of 17 V if on an extended WOT run. My solution was to have high-drain devices running while going full-bore. Usually having my phone charging and the GPS powering up via power ports coupled with a humongous battery kept the voltage under 16 V.
Rgds
E
