I just purchased a 1994 150hp Yamaha Saltwater Series outboard. ($1800 including controls) (Model TXRS) 120 compression across all 6 cylinders, lower unit seals good, good spark, very clean. All and all seems to be a good motor. I have not run the the motor as it was not an option at the location of purchase. Back in my garage I have removed the cabs for cleaning/rebuilding and noticed that the link rod from the carb linkage to the oil injection pump has been removed. I assume the previous owner must have pre-mixed the fuel and that removing the link rod must disable the oil injection. I wish to use the oil injection option on this motor and have read that I can run it at an idle with pre-mixed fuel and check the flow of the oil injection. Does anyone have some instructions to test the oil injector pump? If the oil pump is good, I will purchase a link rod and re connect it. If the pump is bad I will save the $46 for the link rod and just pre mix the fuel. I have a Yamaha ox66 200hp on my other boat and never had any issues with the oil injection. I suspect this thread may draw out skeptics of oil injection. Thanks for any input.
