Re: Will '97 90 hp VRO work on '95 112 hp?
They are both crossflows. My main concern is if there are any electrical differences other than maybe connectors. I don't have the 112 yet to compare them.
If they are both crossflows, I see no reason not. The warning system wiring may be different, as you suspect, but I'm sure you can work around.
I've had OMC's I've run both ways. Some systems intact, some disconnected (not by me).
I have NO fear of the OMC oil injection systems as long as:
1. The warning system is intact and works.
2. The system is maintained.
Water intrusion is its enemy.
We've all heard the horror stories about oil injection ruining a cylinder or two. Total BS. I want someone to explain to me how an oil injection system,
that injects oil BEFORE the carburetors, can destroy ONE cylinder.
