ShowMeGuy
- Jan 31, 2012
- 560
Wasn't there someone on the board that had some End Caps made? The Portside rear one on the 16' supersport is cracked in the corner and has been tweaked. I'd like to get that corrected as I pulled the motor and transom out and cut some new plywood... Titebonding tonight and then starting on the epoxy sealing and fixing some loose rivets along the splash well as well as some prettying up of the SW.
Thanks for the help all!
