Bought a VERY cheap boat/motor/trailer last week. Had been sitting a while. Got the '71 Chrysler 70 hp motor started after an hour of messing with it. Fires up immediately now with hot battery. Put it in the water and it ran really rough with a load on it. Died a couple of times. Wouldn't rev high enough to plane the boat so I just ran it slow for about an hour.
Last week I ran it at home and sprayed carb cleaner in it while running it. Lower unit grease had grey look to it....possible water. Drained it and filled with 90 wt. gear oil. Getting good water circulation. Will wait on impellar. Seemed to run a little better. Then noticed fuel leak at tank connection. Bought and installed O-rings....no more leak. Put boat in water. Ran better, but still missing and not enough revs to plane. Motored slow for an hour or so.
May try sea-foam. Also thinking maybe need to pull flywheel and clean points? Maybe change plugs? Whaddaya think?
Also...and recommendations about what to add to the alcohol-laced fuel we have to buy in order to keep engine damage to a minimum?
