Re: 1976 Johnson 135 - no spark at all. Please help!!
I never said we got a spark by disconnecting and reconnecting any wires.
Sorrry... That was an entry from another member, got a lot going on here.
The parts that you replaced (Stator, Powerpack, and Timer base), are these new parts, used parts that you absolutely know to be good, or just used parts that you assume to be good?
These above items are the main components of the ignition system and it is puzzling that you don't have spark. The following is a normal troubleshooting procedure that technicians with many years of experience would use if that engine was brought into the shop, everything being assembled such as a rig on the water being used and suddenly lost ignition.
1 - Remove the spark plugs so as to obtain the highest possible cranking speed. The rpms must be at least 300 rpm in order for the stator to provide the proper voltage to the powerpack capacitor.
2 - Disconnect the large RED electrical plug at the engine to eliminate the instrument wiring harness along with the ignition switch etc.
3 - Rig a spark tester whereas you can set a 7/16" gap for the spark to jump. The spark should jump that 7/16" gap with a strong blue lightning like flame... a real SNAP!
4 - Use a small jumper from the battery cable terminal of the starter solenoid to the small 3/8" nut terminal of the solenoid that engages the solenoid (not the 3/8" nut ground terminal). This cranks the engine without having major sparks flying about.
If you now have spark, the ignition switch or the instrument wiring harness is shorted.
If still no spark, leave the RED plug disconnected and................
5 - Remove the Black/Yellow wire from the powerpack, crank the engine over and test for spark again.
If you now have spark, the engine wiring harness is shorted. If still no spark... either one of those replaced components is faulty, not grounded properly, wired incorrectly, or the electric starter system is not cranking the engine over fast enough. This would leave you with the task of checking each individual component with instruments if everything is wired right.
