  #1
Old March 16th, 2005, 08:14 PM
Al Kungel Al Kungel is offline
Default waterproofing 12' aluminum boat
What is involved in waterproofing an aluminum boat. It is leaking slowly in few spots. The boat is rivetted. Can the rivets be tightend or can the boat be coated with something?
  #2
Old March 17th, 2005, 02:08 AM
rodbolt rodbolt is offline
Default Re: waterproofing 12' aluminum boat
hello its a pain but the rivets can be "bucked" . it involves two people and a large hammer and a bucking iron. while holding the iron on one side peen the rivet from the other. we use a product callet "Gluvit" with amazing success here. but the bottom must be removed of all paint and oxidation for best results. gluvit is a paint on two part epoxy type product that is made to seal loose rivits. works for a year or so.
  #3
Old March 17th, 2005, 03:17 AM
one more cast one more cast is offline
As rodbolt says but I do it the redneck way. I hold or have someone else hold a 3lb hammer or go devil or any similar large heavy hunk of iron firmly against one side of the loose/leaking rivet and then give the other side of the same rivet a sharp blow or two with a hammer. Hit the rivet just hard enough to expand the rivet and tighten it up not smash it. I actually have a 12' boat that a tree fell on while it was bottom side up and it was pretty much flattened. 10 years ago or so I bought it for $5 and pounded it back into shape with a go devil and a block of hardwood. I had to drill out some of the old rivets and replace them and tighten up most of the others with the above method and I am still using this boat with a 15 hp johnson. NOTE I put the boat in the water and mark the leaking rivets with a permanent marker so I know which ones to hammer.
__________________
OMC
  #4
Old March 18th, 2005, 12:24 PM
NMplayer NMplayer is offline
Tighten them up with the above method. If they still leak, I've used JB Weld to seal them with really good success
  #5
Old March 18th, 2005, 01:42 PM
DJ DJ is offline
Use Gluvit.I have used this product many times with great results. http://www.marinetex.com/PRODUCT%20P...0prod%20in.htm
  #6
Old March 23rd, 2005, 06:38 AM
fire831 fire831 is offline
I used j-b weld on my rivets, and aluminum sealer I got at Lowes on the seams. After everything was dry I painted over all and so far so good.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
aluminum boat... aluminum stringers? diaboy5681 Boat Restoration and Building 6 October 17th, 2006 09:17 AM
waterproofing boat cover carrotsnapper Boat Topics and Questions (not engine topics) 6 February 28th, 2005 02:20 PM
waterproofing boat cover carrotsnapper Non-Boating Technical Topics 3 February 27th, 2005 06:54 PM
Re-Waterproofing Boat Cover Ralph 123 Boat Topics and Questions (not engine topics) 8 July 17th, 2003 06:20 PM
Waterproofing Boat Cover C17LoadSmasher Boat Topics and Questions (not engine topics) 3 February 16th, 2002 07:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
