Re: Bombardier Seadoo XP Help
Everyone has good input so far, i would also ask if the magneto was changed out with all that work.... would have been smart to do. Hit on some things others have said, i owned a 95 XP, 787, ask when the last time the pump stator hub oil was changed. If you look up through the intake you can see the impeller... its not as easy as people make it sound to just "look" at an impeller. You have to remove the rear section of the pump or the intake grate to really get a good look at it, and damage wont always present itself on the leading edge (the part you can see through the intake.) With my XP most of the problems i had were related to things the add says are new, battery, plug wires, starter, OHHH! Yeah, does it have adjustable trim? And does it work? When i bought mine unknown to me was that the seals on the VTS (forget what it stand for, auto trim) that go through the transom had rotted out, and were allowing water to enter and fill the VTS motor housing shorting it out. Out of water it would run fine, put it in the water and it would pop the fuse on the, uh, what was it called, main brain box, MPEM maybe (its been a while) Didnt figure out what was going on until i had already over fused it to find the hot wires and burned up my MPEM ($300) Anyways, make sure the VTS works if it has one and make sure you try it out in water.
