Took my boat out for the first time today. Before taking it out, I had a local marine shop go thru the motor and be sure everything worked. Got it back a couple days later with a good report card. Well, got it in, cranked up, and it started and purred like a kitten. sat there letting it warm up a minute or so, then put it in gear and got out of the no wake zone. Started opening up slowly to see how it would do. Got to a little under half throttle and the motor started trying to die like i was running out of fuel. I've got a full fresh 6 gallon tank mixed. Fuel is mixed according to the instructions. It's the same fuel I put in before I put it in the shop so I doubt fuel quality is the problem. I thought maybe the vent cap on the fuel tank wasn't letting enough air in so I even pulled the cap off and it still did it. Sadly, I turned around and puttered back to dock and re-trailered the boat. I don't get it. I've had the boat out of the shop since Wednesday so It's only sat 4 days. Anyone have any ideas or suggestions? Anywhere before the point it messes up, it runs very smooth.
