DayCruiser
Ensign
- Sep 24, 2004
- 953
Had this Pontoon boat a few years. Yamaha 40 2 cycle. No trolling motor --yet. Stereo/CD player/fish finder/GPS. Came with 2 batteries. I unhook the GPS system after using. The FF is built in
No way to switch between batteries. Big black cables connect positive to positive and negative to negative. Second battery in line has a yellow wire with a black box on it connected to the positive. Second battery has a yellow wire connected to the negative.
I went to charge the batteries up for the season. The first battery inline(closest to the motor) took one hour to charge. The second battery in line took 10 minutes. Why is this? How do you find out if something is running the batteries down? They were low in charge before I disconnected them for the winter. The stereo used to come on when it sat for awhile, so I took the face plate off after each use. Could it still be running? How can I find out if the alternator is charging right with a 2 battery system.
Another question is what are the benefits of having a 2 battery set up like this one? Do I really need 2 batteries? If not, how would I or somebody wire it back one and what AMP would I need? I think the 2 combined are around 1200 amp. ,Matching cranking batteries bought at the same time a year ago. The boat was used just about every weekend during the season. Sat for 7 months during the off season
Thanks in advance!
DC
Thanks in advance!
DC
