Posted last summer about re-building this engine due to a burnt up piston. Since then the engine ran well, except it was slow to get from idle to full throttle rpms. If I punched it all the way down, it would hesitate, sometimes for over 30 seconds, and then it would run up to full rpms. After that, it would run well.
I decided to run some carb cleaner through it to see if that helped. Used cleaner that mixed in the fuel. I ran the boat for 30 minutes at @ 85% throttle. Then I came to an idle only section of the lake and had to idle for 10 minutes. When I left that section, it still ran fine, but would not throttle up above idle. If I held the throttle down all the way, it continued to run and felt like it "wanted" to rev up, but it would not. Eventually it would stall.
This is what I have done so far:
- replaced the fuel.
- replaced plugs and checked each piston to be sure they were firing.
- rebuilt all three carbs
- checked all fuel filters to see if they were restricted.
- checked the fuel pump for obstruction by squeezing the bulb and got good flow.
I really don't know what to try next. When the engine is running, I can sometimes get it to rev up to 4500rpms in neutral, but in gear it just does the same thing as before. Sometimes I can get the engine to "react" by hitting the choke, but it does not ever get up above idle.
Is it possible the fuel pump is not working to push more fuel when I throttle up.
Any help would be greatly appreciated. I really can't afford to leave it at a mechanic to work on.
Chieftain
Chieftain
