Carbs overhauled and synced both full open and closed. Control cable connected at full closed. Timing checked set at 4 degrees BTDC while running on water muffs. Low RPM is 1200. Not likely to drop to 700 +/- in gear on water. I suspect from reading Evinrude threads, further idle adjustment is done by changing low speed timing. Would someone please confirm this and is the timing retarded (later) or advanced (earlier) to lower RPM. Thanx. PS No, these carbs don't have idle adjustment mechanical or metering and butterfllies are to be fully closed from what I have determined from similar engine threads.
