What spark plugs are you using in your mercruiser 302's???
aroncornell
ok guys, next question. Ive been doing some looking and not finding much info on spark plugs other than marine plugs are like $20 a piece and i do not wanna spend that much. I found the NGK AR6fs plug is used in a marine setting and the price is a lot better. So just wondering what you all use in your 5.0 liter???
achris
More fish than mountain goat
Re: What spark plugs are you using in your mercruiser 302's???
Be careful here...
The plugs for your engine are NGK A6FS
For a GM engine they are BR6FS
Chris.......
aroncornell
So is it safe to say I can run the NGK AR6fs in my ford 302???
Don S
You want the A6FS not the AR6FS your engine does not need the R (Resistor) plug.
aroncornell
gotcha. thanks for the reply
