I recently purchased a 1999 Bayliner Capri 1750 that has a Mercruiser Alpha one 3.0 with a 2.0 gear ratio that came with a 15x17 OuickSilver prop. I am going to need to replace the prop, so I called Bayliner and discovered my boat was outfitted from the factory with a 14.25x21 prop. I want to know everyone?s recommendations as for a replacement prop or should I just stay with the 15x17. This boat is used for occasional cruising but mainly is used to pull 2 tubes or a skier, so top end isn?t much of importance as gas mileage & being able to get on plane quickly with a skier or tubes is.
Thanks everyone in advance for your advice & recommendations?.
