Riviera M370
- Apr 7, 2013
- 14
Hi All, I have a Sunrunner 33 foot with a couple of 4.3 MPI Mercruisers. I have this electrical problem that I cant seem to sort out and by reading these forums I believe you all will be able to help me down here in Aus. When I turn the port ignition on I only read 10 volts and the engine starts as if it has slightly low battery volts, once started it has seriously high battery volts 15 volts but wavering on the gauge. The Starboard engine shows a healthy 12.5 volts and starts easy with 13.8 volts while running and the gauge is steady as a rock.
As I didnt know the age of the battery's i decided to buy 2 new ones, N150 marine maintenance free, I also purchased 2 brand new starters and 2 new alternators from the USA. Essentially I have had absolutely no change to the port engine starting issue the only thing that was noticeable is the voltage reading is now steady as before it was wavering.
It still reads 10 volts on ignition on and 15 volts when running is there something else I can look for
