We are putting the tiller setup back onto a 1977 Johnson 25 outboard and wiring was cobbled up for the key and other stuff. Starter is hooked up using key or push button now, not sure which (starter acting up) but question is, i need a way of shutting it off. For pushbutton setup, need a kill switch so I'm wondering what wire i need to open/close through the switch to ground to get the engine to kill? gotta be some yellow wire with stripes on it for the cdi/coil but not sure which one has to be used for kill switch...or what to hook up if using a key switch? any help apprectiated, thanks
