what year is my 225
papasmurff67
have only the power head was told it was a 1987 but reading other post i think it is a 1988 r newer motor heads have the #333809-3 on them quarter size plug on exaust housing is G2505128 it has the butterfly style electronics this is also a VRO engine n is it a looper motor
Greg_E
Re: what year is my 225
It looks like it's an '88 or probably newer. Yes it is a V6 Looper with VRO. The number stamped on the plug is the serail number I think. They started doing that at some point after 1988 instead of putting the model number. If you contact Evinrude, they may be able to give you the model number. I had an engine that I stripped for part that had a similar number on the plug. I determined that it was a '90 or 91 by some of the parts on the engine that were specific to those years.
boobie
Call BRP customer service at 1-262-884-5993, give them that # and they should be able to help you.
Greg_E
I tried that number and got a recorded message. Something about you have reached tech support and if you already had a case open they would get back to you. It doesn't seem to be the correct number for the general public.
Update:
I looked for another number and this is all I found. I guess if you can't get through you can write. I also read on the BRP site that they don't support any products before 1994.
"Call us at: (262) 884-5993 (same number boobie posted)
Or write to us at:
Evinrude Dealer
and Consumer Support Services
10101 Science Drive
Sturtevant, WI 53177
Available Hours: 8 am to 4:30 pm CST
Technical Contact Information
We Take Your Boating Pleasure Seriously!
Your selling dealer has a special interest in your satisfaction and should be consulted first if you have any concerns about your Johnson power product. Your authorized Evinrude dealer is your primary contact for service, product information, and Evinrude and Johnson? Genuine Parts.
Protect your investment. Please read your owners manual for all operation and maintenance information for your engine. It lists all the adjustments and routine maintenance procedures for your motor, including off-season storage and pre-season service. We encourage you to work with your authorized Evinrude dealer for all the services you require.
If you have a concern with your engine that your dealer is unable to resolve, please have your engine model number and serial number available, and contact us at:
Evinrude Dealer
10101 Science Drive
Telephone: (262) 884-5993
Available Hours: 8 am to 4:30 pm CST"
boobie
You should call that # again and see what happens. I'm going to call it tommrow and see what goes on. I'll get back to you. Sorry I meant Monday.
boobie
I found out today you have a J200STLES. That makes it a a 1990 200. I got through on the phone okay and the guy gave me the info. Hope this helps.
Greg_E
I guess the OP got some good news and some bad news. It's two years newer but 25 HP less.
Faztbullet
If your going to run it at least correct the plumbing of t-stats or do the t-stst update as whats on there now is wrong... dont see how t-stat could pop off the seats......
Greg_E
Starboard side has the wrong t-stat cover and you need to fix the hose routing.
This should help.
http://shop2.evinrude.com/Index.aspx?s1=8nd0t9o2c5aeru3d7bd7hbgu41&catalog_id=0&siteid=1
Hose should go from the water control valve to stbd t-stat. Another hose connects to the other hose nipple on the stbd t-stat cover and goes to the port t-stat cover
Your going to need a manual sooner or later, so just bite the bullet and get one now. You can find used OE OMC manuals on Ebay for around $30. Just be sure you order the correct year. Research the correct manual PN for your model and year. Many of the sellers incorrectly list the year the manual is for.
Look at the pictures on page 2 of this thread. It should have most of what you want.
http://forums.iboats.com/johnson-evinrude-outboards/1988-johnson-v6-vro-info-595858.html
papasmurff67
would anyone know the correct manuel for my motor i guess the cawling has been changed because it has 225 vro on it
papasmurff67
i think i read on another post that there was another number under the block that would take all dout about what kind of motor it is is this fact r did i dream it up
Greg_E
This is what you have. Boobie did the work for you.
Use the search function. Learn how to look up the number of the manual and a order it, or should we all come fix it for you?
