natedog337
- Jul 11, 2011
- 107
Guys,
Just unwrapped my boat and prepping for the season. When I was checking my throttle I am able to move it to reverse and then downward as if I was backing and increasing throttle. So the reverse seems to operate as it always does when the engine is running. Now from neutral I can move the throttle into forward gear but then it is extremely tight and will not go forward as if I was accelerating. This is only my second year with the boat and I wasn't sure if the motor needs to be running in order for the throttle to move forward freely or if I may have an issue. Figured I check with you guys before dripping it as I'm not sure if this is an issue or normal. Thanks as always...
