20 hp with excessive Vibration
MKD
Just bought a new 2013 20 hp electric start Tohatsu and it seems to have a great amount of vibration. The dealer said he prepped and started the motor and found nothing unusual. I took it home and run it the river and the vibration can be felt thought the whole boat. Has anyone else had this kind of problem or am I just expecting a four stroke to run smoothly.
Thanks
WN2712NJ
Re: 20 hp with excessive Vibration
Hard to say what is excessive... I have the same motor (08 vintage) and it is reasonably smooth, particularly at speed. On my 14 foot tinny, there is a definite resonance somewhere around 1500RPM and you don't want to stay there long. But that might be the boat as much as the motor.
Close to idle, it's ok, but not as smooth as my 1956 Evinrude Lightwin 2 cylinder. But that's not surprising given you've only got half as many spark plugs firing per rev of the crankshaft.
If you really want to feel rough, try any single cylinder 4 stroke kicker.
-dm
Sea Rider
Probably the sliding load of the steering is very light, check, adjust lateral bolt. Load should be adjusted bit heavier for engine to run straight at fast idle when you release hands from tiller. Other issues : engine clamp screws not adjusted tight, stern's bracket rod & bolt slighty loose, check.
Happy Boating
