I have a quick question for you guru's out there. I've been lurking here reading and studying and searching the forums. A LOT of good information here and for that I thank you! here it is:
I recently traded for a 1988 Procraft 1600 V bassboat. I traded a truck I'd had sitting around the yard. Anyway, listened to it run when I went to look at it, but didn't put it in the water. It started pretty good actually, though he could have went out an hour before I got there and warmed it up. Anway, I put it in the water and it ran ok. He had told me he had put seafoam in the gas before storing it for the winter. I am very much a fan of seafoam BTW..... Ok so I filled the tank, put it in the water and ran it about 3 or 4 miles to my favorite fishing spot. It ran good, but occasionally would bog down. It would pick right back up again though. But I smelled gas awful. When I got back in and trailered it, I noticed gas running down the leg. Further inspection showed dry rotted gas lines. Ok, not a real big problem to replace. This isn't my first boat, so I'm ok with doing minor repairs myself.
Replaced the gas lines, went back to the lake yesterday to run it, it wouldn't start. went through the cold cranking procedures, nothing, nada....turn over good would not start. Thought maybe I'd gotten the choke solenoid out of postion, pulled the breather silencer and it appeared to be working well. The battery is 4 years old, and would drop to about 8 on the volt meter when trying to start. So I'm thinking maybe that's it......so anyway, I use the trolling motor to fish some tree tops around the boat ramp, the spots are hitting just about anything on Lake Allatoona here in NW GA btw.....let the motor rest while fishing and tried again. I did finally get it to start, but it wouldn't pick up at all. The fast idle lever made it run, but it was one of those quick hands maneuvers to get from fast idle, to low idle in gear before it died. And it wouldn't pick up at all. Brought it home, charged the battery. Noticed some wires loose, which might explain why the TT didn't seem to be working right. Anyway, put it on the muffs and it starts right up, runs great sitting here in the yard. My question is, was it the battery all along? or am I going to run into problems when I put it back in the water, maybe the back pressure from being in the water vs on the muffs was too much? I'd like some opinions before I drive 40 minutes back to the nearest water to test.
Sorry for the long first post, I know from being on a couple other forums, there's not really such a thing as too much info in the description (as long as it's relevant) Thanks Chaz
