oldcatamount
- Apr 4, 2010
- 1,740
I have an '83 Johnson J25ECTD that's not firing on top cylinder. I can start the motor quite easily but it's "sneezing" at low rpm. The top plug is very wet with unburned fuel and the bottom plug is sooty but dry (plugs are new). Good spark with air gap tester, good compression (135 on both), very clean carb. I have swapped the coil positions with no change. Does this sound like a bad power pack? Does this ignition system require a battery when it's running? I removed the flywheel and cleaned the magnets with 400 grit paper (lightly) and it didn't help.
