cheiderman
- Apr 8, 2013
- 3
I have a 1982 Chrysler 9.9 outboard that will not stay running at idle/low speed unless you keep squeezing the primer. I have replaced all the fuel lines, primer bulb and fuel pump/diaphragm. In addition i have taken the card apart and cleaned it. The one area I'm not sure if the gas cap on the external tank. The gas cap is old and is missing the top so the there is a small hole. I went to replace the cap but all they sell are the new ventless caps due to the emission regulations. I was hesitant to put that cap on in fear of having vapor lock. Any suggestions would be appricate it.
