280 out drive boots
captmello
Re: 280 out drive boots
#26 is the exhaust bellows
Connecting Components Aq Drive 280 AQ260A - 7744020 - Volvo Penta
#67 is the ujoint bellows
Upper Gear Unit: Drive 280 : DRIVE 280 - 7744020 - Volvo Penta
you'll also need #7 and 31 (orings) for installing the upper gear assembly.
BTW, if you're ujoint bellows is "Thrashed", you'll most likely need ujoints, at least.
Pull the upper and have a look before ordering your parts. Here's how.
http://forums.iboats.com/mercruiser-i-o-inboard-engines-outdrives/outdrive-side-pin-removal-309095.html
PiratePast40
You might want to perform the pressure and vacuum tests before disassembly, so that you're aware of other seals and o-rings needed.
Thanks for the response. The diagrams and info were very helpful. I will need the u-joint bellows for sure. The boat has been baking in the Louisiana sun for years and hasn't been run so I hope the u-joints are okay. Do I just check for slack? The lower unit oil was clear. Is that a good indication that other seals are okay.
