LilRedNeckGirl
- Jan 25, 2010
- 184
As most of you know, I run a 1985 wellcraft, twin 3.0 140 horse 4 cyl engines.
These are old style @ points ignition, with carbs.
Its time to rebuild the engines. Low compression { from Zero in one cyl, to 90 in the highest, with no engine reading all good pressures} , rough idle, etc, dispite our best efforts to get them right. They are old & tired for sure....
In process, I need opinions based on fact, about upgradeing the points system to electronic ignition, and if an upgrade is feasable on doing away with carbs and going to either throttle body or fuel injection.
Additionaly, if these, either or, are good ideas, where can I get the new distributer / fuel system.
Engine Ser# 6692520 & A311092 { Im guessing one was replaced at some point before I bought the boat. }
PART 2 ; In doing this repower/ rebuild, what are my options on new engines? I looked around, and can buy new for around $2500.00 but these are the new Vortec blocks. Will they be bunches of adapters, conversions and grief? Who sells direct bolt in remans? Can I go to 6 cyl power plants and still count on direct bolt ins? Should I stay with a local rebuilder just to keep it simple?
