Charleszodiac
- Apr 6, 2013
- 2
I have a yachtline 480dl. The hull takes on a lot of water while at speed. When idling or going slowly it does not take on water. When cruising at 20 knots, it takes on a huge amount of water. I have completely filled the hull with water with no leakage. I have removed the tubes and there is not an obvious crack at the deck/hull join. There is a small space at the back of the tube track, but this has never been an issue in the past and does not leak when the hull was full. Any ideas? Thanks, Charles
