CaneCutter79
- May 24, 2009
- 454
Did Evinrude provide a standard spec or recommended compression rating for a motor? I just had my rebuilt with a re-sleeved cylinder and all new pistons and rings. I have about 4-5hrs on the break-in and I'm getting 110psi on 3 cylinders and 115-116 on the re-sleeved cylinder.
Is that low? I was expecting 125-130. If it was rebuilt correctly, the pressure should be higher than this correct? This seems low to me. I'm going to have a hard time convencing the mechanic its low unless and asking him to re-build the motor under warranty unless I have some standard to go on.
Should I be concerned about these readings? I know it's a bit early and the break-in is not complete yet but I can't understand how it could jump up or increase in compression later. I tested the compression after I got the motor back and the readings were 110 on 3 cylinders and 125 on the resleeved. It's now dropped to 115-116. That's why I'm concerned.
