Re: Idle issue
First of all welcome to Iboats forum...:welcome: Good to have you aboard...
Sounds like you have a fuel delivery issue. DON'T use starter fluid to start your outboard again. It washes all the oil out of the bearings and such and makes your outboard run without any oil protection. That's a huge NO NO. If you do want to start your outboard use a squirt bottle of 50:1 gas/oil mixture exactly like in your fuel tank. That is a safe alternative. But you have a fuel delivery issue that needs attention. When was the last time you run that engine? If it has been sitting for a while, do a carb rebuild for starters. You can also check your fuel pump to see if it is working. And last but certainly not least make sure your tank, fuel hose and primer bulb are all in good condition as well. Does the primer bulb pump up and gets firm? If not, start there and replace it. Next make sure your fuel pump is supplying fuel to the carb(s). If all that is good, it is your carb next...
