I replaced the coils and plug wires, the problem is it runs fine except at low idle then it starts missing. I cleaned and gapped the points and checked the resistance, zero ohms when closed. tried new plugs, it will run ok for maybe 30 seconds at idle and misfire again. when it starts this it sounds like it"s running on 1 cyl. until the throttle is past start then the other cyl. kicks in. what now? it will run fine at half throttle and faster.
