A break in the weather!
Homerr
Well, a few weeks ago, my project has 6" of snow on it, and now it's 50 degrees outside and rather nice. <br />Perfect for doing my stringer work.<br /><br />Anyone have suggestions on removing some minor moisture before I glue my last set of stringers in?<br />I had about 10 gallons of water on my tarp after the snow melted. Some of it seeped inside.<br /><br />I know spring weather would be best, but lately it would either be too darn cold, or too hot.<br />I want to take advantage of the mild weather over the next few days before another storm hits.<br /><br />I only have one side (2 stringers) to go and of course the plywood on top.<br /><br />Thanks,<br /><br />H.<br /><br />
pjc
Re: A break in the weather!
Sweet rig Homerr <br />High of 35f here tomorrow. My projys frozen in time. Dammn-hope you get some work on your projy done! :)
pjc
Sweet rig Homerr <br />High of 35f here tomorrow. My projys frozen in time. Dammn-hope you get some work on your projy done! :) <br /><br />(EDIT)- sorry for the double post--iboats warning about some sort of flood protection function software process enabled--when I refreshed as instructed,-viola-two posts. :confused:
A Shop-Vac..<br />And a Heat Gun come to mind.......<br />Dry it Out,+ Warm it Up......<br /><br />Got All the way Up to 0* today here....
Homerr
Yes... I had to clean up the floor with the shop vac, and got the few puddles of water.<br /><br />A heat gun is an excellent idea. I'll borrow one from work. We have those heavy duty industrial type... Not the kind to dry your hair unless you want to burn it off!<br /><br />H.
JasonJ
Yeah, if you are glassin' you'll want it completely dry, and at least about 60 degrees or warmer. Good luck...
