my 1997 evinrude 115 hp won't run without priming it constantly. just put back together after two months. it will run fine idling for a few minutes, but when you take off, it's as if its running out of gas. choke it and it runs fine for ten seconds and then you have to prime it constantly for it to run.I just put a new starter on it, new impeller, did a compression test, 125ft lbs per cylinder. just trying to get back on the water. any ideas?
