Texasmark
- Dec 20, 2005
- 14,558
Over the winter I cleaned out the carbs and put in a new impeller. Every thing went without a hitch. Fired it up on muffs afterward and was very pleased with the results. All systems go.
Yesterday I pulled it out to get it fired up as the weather is warming and we are getting some rain here which is moving the lake closer to the ramp. Yes!!!!!
So on the muffs, start her up without too much trouble considering how long it has been sitting and my otherwise robust pee stream is just a slobber.
Remembering that I ran it after doing the work and all was fine, and the fact that it went back together without a hitch, and just sitting in the garage the water pump wouldn't just go to !@#$, I headed for the pee tube. But first I took some temp readings around the block and noticed that I had water coming out the lower unit in the right places, all of which said the pump was pumping and that stat was "stating" (my pee is plumbed off the exhaust manifold directly anyway...some plumbed off the stat output).
Pulled the hose off the hose barb at the manifold and couldn't blow through it....great. Smoking gun. Ran a wire through it and played with the little adapter at the end until I got it unclogged. Never saw what it was.
Reinstalled the hose and wala. Robust pee.
Since it was winter the insects haven't been about so all I can surmise is that in redoing the pump, I dislodged something that wound up in the tube, but everything was clean when I opened her up to do the impeller. Got me.
So, you just never know if it's ready to go or not.
Mark
Mark
