loose rivet
- Jul 31, 2011
- 151
I've been looking for a good running motor for a boat I've got here all winter, I came across a great running, super clean looking 1989 50hp Evinrude today, however, there's to issues, one its a 15" shaft, I need a 20", and second, the tilt ram has been cut off with a torch, the upper part is still hanging from the cross shaft.
The motor comes with controls, oil tank, and looks like new other than the butchered tilt ram.
First off, can this be converted to a long shaft? (I have a blown 1989 50hp long shaft here but also with a seized tilt ram and no lower unit.) If the lower unit from the short shaft can be made to work easily, I'll buy the tilt cylinder.
The motor is cheap, the guy needs cash and will let it go for $300 with the controls and tank. I figure I can get a new tilt ram for around $1500 used, a local dealer has a good one here.
The next best deal I've found is a completely rebuilt 1982 50hp at another dealer for $2750, but that motor looks to have seen lots of saltwater use.
