It wont go all the way up into trailer position. How to fix??
ive pushed both button at the same time and it only goes to a about a 45 degree angle. I see other boats at a approx 80 degree angle is this just wishful thinking or what. I can winch it with a strap up to the 80 degree angle but not with hydraulics.
Does the motor stop running like a switch shut it off? Or does the motor keep running, it makes a different sound, but stops moving. If the latter, see achris's post above.
It goes to a higher pitch,continues to run. The oil level is good.
The rams are two years old.
oil level is at plug. Bled system by bringing up and down approx 10 times. It goes up and down with no hesitation it just wont go into the trailer position ( or what ifeel is trailer position) The rams are two years old. They hold the outdrive up until I bring it down (i've left it up for three weeks without any dropping)
Yep that is why it doesnt make sense. it just wont go into trailer position
Well they look the same I used a 233 outdrives rams on the 888 with the 233 ram. The only difference was the trim sender that i bypassed, the old ram style not the ones on the side of the outdrive.
Removed hydraulic lines and hooked wires together. The cylinders never worked properly this is why I replaced them with the 233.
have you tried testing the wires on the inside of the transom to see if there not broken or rotted through.you maybe able to connect together inboard for testing purposes.
